Post the full size picture of the first one. It looks like there could be some but its so oily and dirty I can't compare. Can you pinpoint where the oil is coming from? My bolt snapped but it stayed in place with enough less tension to crack the gasket and there was no visual indication other than the soot. The kombi gasket is cheap so just replace it when you pull it. Does the sound disappear after a few moments after a cold start up or is it continuous?
Here is the full size of that first pic, I was going to pull the intake and look with a mirror, but figured I had a good enough shot from here. If you think pulling the intake stage 2 piece and heat shield and looking in there with a mirror will get a better angle I can do that tonight. AS for the sound, it is on start up occasionally, lasts for a few seconds then goes away. It will come back randomly. The conditions it seems to come back in most often are after cruising in 5th or 6th at highway or freeway speeds for a few minutes and then exiting, the noise starts when I rev it after a long bit a steady RPM whether I rev it up with the clutch disengaged or engaged and accelerate. If I push the clutch in and run the RPMS up to 5 or 6k rpms it goes away and doesn't come back until I've driven under typical conditions above. Occasionally it occurs at random but that seems to be the most common way to replicate. The other way I've been able to replicate it is shut the car off for five to ten minutes after it being on for any amount of time. Coming back and starting it again and it's there on start up even if it wasn't the previous drive at start up. If I let it sit for an hour or two to cold start, it is completely random if I have the noise on startup.
Lastly, It appears that the oil is coming from that outside bit on the vacuum pump as oil sits in there, very heavy gunk that is visible in that third picture. But it seems it could also be coming from the kombi pump gasket. At this point I'm thinking that the oil leak and sound may be separate issues. I will order the gasket for the kombi pump next time I get something from ECS, probably in the near future, can't justify 7-8 dollar shipping on a 4 dollar gasket lol
