sauceman101
Bump for an update!
great minds think alike, was typing when you bumped haha
Bump for an update!
Bump. Any updates? Can't find what's causing this noise..
Have you been able to take apart anything and get back there to take a look?
Wasn't the pcv valve then? They screech like mad when they go bad
Not yet. I am going to do it this week hopefully. Just checking to see if this got rid of that noise. Also how long is this job?
I'd assuming changing the exhaust manifold gasket is probably a 6-7 hour job if it goes smoothly. It's no different than replacing the turbo really.
The screech noise is a pre turbo noise not an exhaust manifold gasket. You can verify this by reinstalling your stock intake. If the sound level does not change or diminish then check boost pipes first.
Damn lol. Is there any damage caused, over the long run, from not fixing the gasket leak/bolt?
Hmm so it's not something that is an urgent-must-fix?
It's not too bad replacing the manifold gasket if your a DIY'er, its getting the snapped stud out if that's what happened. Turbo manifold was slighted warped for that exhaust port too. Question for me was what came first, the snapped stud, the gasket, or warped manifold? I tried to argue with VW to pay for it but they said all three were not warranty parts. Then I tried to argue that the warped manifold is part of the turbo which is warranty. Then I tried to argue its an emissions issue which is a warranty item too. No budge, $800 to have a specialist come and drill it out.
Long term issue I noticed was it would leave my engine bay incredibly hot.
If my manifold is warped then I won't have this noise resolved until I upgrade the turbo in the year, hopefully it's just a busted gasket
