So everything installed and loosely dialed in. I was like 2 inches too short so I had to search all around the city for a piece of plastic fuel line. So you can see in the pictures the line with the yellow heat shrink will be replaced as soon as the additional 4mm line I ordered from aquamist. I ran the line from the pump in the trunk under the car right next to the fuel line (there's even an open spot along most of the way in the clamp). I put my controller in the glove box. I know most people install it inside the passenger fuse panel but I ran my wires through there and into the glove box, which works better for me. Overall I couldn't be happier with the quality, customer service, research, and results from the HFS-4. It is a fairly extensive install, but I did it in 4 days about 10 hrs a day. I also cleaned my valves. Had to wait for dealer to open to purchase injector overhaul kit and a bunch of other repairs/PM. I am still in the very beginning stages of dialing in the system and logging results. I have logged several times before but I still consider myself a novice in that dept. so I will be doing a lot of research. Thanks U20T for posting the CCTA ECU plug pin #s. I was not 100% sure and I saw what u posted and it confirmed. And HYDEs YouTube video of his set up pointed me in the right direction for the settings on the board to start from ground zero.
CLICK ON "MY OUT-DATED BUILD" LINK IN MY SIGNATIRE TO SEE THE PICTURES. . I can never get these freakin pictures to show in the post.
