Hello all,
4th of July morning my 2011 VW GTI had difficulty starting. It took 3 button presses to get it to turn over. The first time I felt may be I didn’t hold the button for long enough but it still didn’t start until the third time. Yesterday morning I stopped to get some coffee and when I started the car it had a rough idle and then stalled. It started right back up without issue. So I did a scan this morning (see below). I do have staging enabled so I’m not sure if the error code is related or not. The engine not turning over has happen before but the last time it thru a CEL which went away the next time the car was started. The dealer preformed a scan the last time this happen but never found anything. Any ideas as to what the problem may be?
Thanks,
Staudie
Friday,06,July,2012,07:09:52:46537
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 7N0
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55
56 62 72 77
VIN:
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AQ HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H25--- Serial number:
Coding: 040301081C070160
Shop #: WSC 01357 011 00200
VCID: 75CF38BC1CDA171
1 Fault Found:
005386 - Engine Off Timer Performance
P150A - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 243 /min
Load: 88.2 %
Speed: 0.0 km/h
Temperature: 29.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 10.541 V
Readiness: 0000 0000
Thanks,
Staudie
Chassis Type: 7N0
56 62 72 77
VIN:
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 243 /min
Load: 88.2 %
Speed: 0.0 km/h
Temperature: 29.0°C
Temperature: 33.0°C
Voltage: 10.541 V
