JT641
Banned
i believe its not an issue with 6spd transmission
They're both 6spd
They're both 6spd
i reckon that he has a DSG?
What I mean is, Is the Manual harder to get to this bolt or is it the DSG??.
No, if we talk about the front bolt of the LCA it's easy on a manual and hard on a DSG.
correct, because the DSG transmission is a lot bigger and blocks the LCA driver side bolt and will need to raise the engine to get to it which requires unbolting the engine mount.
yup, just trying to get as much info out there so people can find it.
here are some picture of APR BFG MaxR 6speed build with SuperPro LCA
another view with a 6spd
So if these work on a GTI, does that mean the Audi TT ball joints will also work without changing the lower control arm?
Seems like they should, just need bolts to go along with the new ball joint. I need a new ball joint is why I'm asking. Figured it might be smart to just put the Audi or equivalent on instead of getting the fixed GTI joint.
