fun fun
as you know it never ends
fun fun
Feeler - AWD swap parts I have stocked up for the MKV, will go to a good cause (mk6). Good trans case 40k miles AWD DQ250 with T-case and wacetrac (you would need to swap in your DSG gear set, was going to do this on my mkv [clutch packs are good still], would come with new clutch cover), rear subframe and knuckles with basically new bearings and abs sensors, bracket to the engine for tcase, passenger front axle new within 500miles, rear axles (one is no good you can possibly rebuild it or use it as a core, outers cv is no good), ABS module, cross over brake line (brand new), I have the driveshaft brackets for the tunnel as well (brand new).
What you would need - Haldex, drive shaft, one rear axle, gas tank and pump, should be able to get all of that for ~$1k.
I am figuring no mech unit with the trans at the moment but we can talk, it will only work properly on Unitronic stg3 engine software so you can swap you mech unit in or swap to Uni or w/e we can work out the final details.
Buy this and I will help code and wire (diagrams etc).
I want this so bad! No way I can afford this and BT over the winter though :-( GLWS!
make sure you do an awd compatible kit if you want awd
Good to know! Debating on building the tsi or building a 2.5. I know it won't make as much as the 2.0 can but the noises it makes... ?Dsg will do 600 no issue on a 4cyl all day long
