dcpppf
Looking to do the same setup on my Premium 8 in my R. I can tell it also has the factory bass protect issue so this is a great fix.
Only questions are the actually wiring with the factory HU since there is no Dynaudio amp. Maybe I'm getting confused with where to hook up the amps speaker and remote inputs from. Anyone have DIY? Only installing a sub pretty much OPs set up.
Don't take this and run because I'm no audio expert, but I believe that the setup will be the same regardless if you have a dynaudio amp or not.
The ONLY thing you need to "connect" to the stock system/wiring are the taps to the LC2i (or other LOC). You'll need to splice in wire to run between a speaker on the left side (front or rear) and the LOC's "L speaker level input", and another between a right side speaker and the "R speaker level input".
Aside from that everything else is independent of the stock system. Amp and LOC take power directly from the battery, grounds are to the chassis, the LC2i remote turn on is fed via the speaker level inputs (that get spliced in to stock system), the amp speaker output goes directly to the sub, and the RCA cables go from LC2i to amp. I think that's everything.
