HYDE161
This review is going to serve as a part 2 to my original “HYDE16 Reviews - SoCalPorting K04 Turbo Port, Polish & Exhaust System Coating” thread which discusses the baseline Mainline AWD 1800 chassis dynamometer numbers for a ported and polished APR K04 turbo with APR V2.2 software. This part 2 review will focus on the performance gains solely from bolting on the TSI HPA 2.0T Performance Intake Manifold with no other changes to the car. The software used in this test has remained the same but the ultimate gains should come from the upcoming HPA remapped software file. Lastly, this review will also serve as a DIY install guide for TSI owners. As a supplement, I also referred to the available -HPA 2.0T FSI Performance Intake Manifold Installation Sheet-.
Product Description:
HPA Motorsports is excited to introduce for the first time into the global market, a high performance intake manifold for the Volkswagen 2.0T family of engines. 2.0L owners have been waiting for a product like this since the engine's launch in 2006, and now it's finally here. Featuring better flow, higher boost capacity, and integrated flapper delete; this product will take your 2.0L VW TSI and FSI to the next level. A direct bolt-on replacement for your OEM plastic intake manifold, HPA's performance manifold features a 40% increase in volume over the OEM plenum, and its cast aluminum construction supports larger turbos and higher boost resulting in big potential performance gains. HPA's technical partner, HGP Turbo in Germany, designed and developed this product over 2 years ago for European Golf-R applications to meet the strict TUV and European emissions* regulations. We embraced the system for our Project Gold Rush build in 2012, and have now acquired both the design and the tooling for production in North America, and tweaked it for both street and track use on FSI or TSI engines. By producing and finishing these intake manifolds in Canada, we've been able to drop the price-point significantly over the original European offering, while maintaining the same quality level. HPA's performance intake manifold is cast at our local foundry and machined in house at our development center in British Columbia, then powder coated with a satin-black finish for durability and greater heat dissipation.
Unboxing & Initial Impressions:
-The clean packaging included all necessary bolts, washers, boost taps, plugs and sealant
-The overall weight of the HPA Performance Intake Manifold is extremely light
-The HPA Performance Intake Manifold has an excellent smooth and durable exterior finish
-The inside of the HPA Performance Intake Manifold plenum does not follow the same exterior contour but there are no burs or extremely rough surfaces
-The HPA Performance Intake Manifold plenum runners are ultra smooth
-The optional pre-drilled/tapped water methanol version of the HPA Performance Intake Manifold has one bung post throttle body facing under the plenum
-For ease of servicing water methanol jets, I think HPA should relocate this bung to the front of the manifold if possible
-The manifold was designed with the similar mounting points to re-attach the majority of the OEM lines and brackets
Pre-Production Packaging:
Hardware:
Manifold:
Front:
Side / Boost taps:
Top:
Backside:
Machined Head:
Underside:
Underside Front:
Throttle Body & Meth Bung:
Throttle Body:
Inside Throttle Body:
Inside Runners:
Driver’s Side & Boost Taps:
Passenger Side:
Preparing the HPA Performance Intake Manifold PCV Connection, Boost Tap & Plugs:
Since my 034 Motorsports Catch Can doesn’t use the factory PCV connection on the intake manifold, I contacted John Pelton at 42 Draft Designs for a one-off brushed aluminum plug with rubber o-ring in the same M14x1.5 thread. The original included HPA crush washer was not re-used as the 42 Draft Designs plug has an o-ring. If anyone needs a plug due to their catch can configuration, contact John Pelton at 42DD for these plugs in brushed aluminum or silvers/satin/wrinkle/bronze powder coating. Also installed were the included HPA threaded brass boost tap and plugs.
Preparing the HPA Performance Intake Manifold For Water Methanol:
As shown above, HPA elected to outfit each manifold with a single threaded bung directly below the throttle body base. As per HPA, the TSI and FSI HPA Performance Intake Manifolds have nearly 100% equal flow across all runners (on their test bench) and their experiences have shown sufficient atomization at this point of entry. Since my Aquamist HFS-4 water methanol system installation was not complete, I decided to use the included brass plug to block the one bung post throttle body for now. While the HPA Performance Intake Manifold was awaiting installation, I also decided to drill/tap direct port bungs fitted with Aquamist jet holders and jet holder plugs. This could allow future expansion of my Aquamist HFS-4 system if I wanted to run a direct port water methanol software file. For now, the one bung post throttle body and these direct port bungs are all plugged.
