WASHER FLUID LIGHT WONT GO OFF!!!!
Brandon Root
its friggen nuts! i called my dealer and they said it could be a bad sensor but i would have to buy a whole new resovior..not happy
The Fixer
You can probably just jumper the plug to it and call it a day.
rod12
any updates on this mine just went on.
Calvinball
Yup, for a month for me.
Looks like the Polar Vortex has affected it.
Huh. I asked because mine will come on when it is particularly cold out, despite a full/nearly full reservoir.
I have no answer for you then.:cry:
beantown53
On another website, a user posted this:
"Here's a fix for you! Pop the hood, open it up, and press down firmly on the cap of your washer fluid reservoir. Problem solved.
It doesn't mean that there's anything wrong except that your cap isn't securely fastened!"
Very easy to check. Let us know if it fixes your problem.
dcarony
This
Norsk
tried that. It doesnt go away. It has to be bad sensor.
JhnR
Bad sensor, if the cap is on secured properly.
