barische
I changed the oil today, had to re-use the hex plug back on. I was thinking the washer on the original 19mm that i took from past oil change would come off but would not make it past the threads.
I put a copper washer on the hex plug and torqued it down. Filled it up with oil. Drove about 50 miles checked it three times no leaks yet. knock on wood.
I just ordered the 19mm original drain bolt and Magnetic plug from ECS which will install soon to be on the safe side. hex plug has about half threads of original 19mm. seems like i was able to get a good crush on the copper so its not leaking.
