BoostedVW11
Damn i cant wait till i go k04 if ever.
My boost looks very similar to yours ;-)
EDIT: Also have Bilsteins, Super pro, Stoptech ST-40... Did you try Unibraces? a must...
To find your local atmospheric pressure, simply log your boost with the key on/Engine OFF. Subtract that value from your full-throttle boost readings and you will get your gauge pressure in millibar.
Multiply your gauge pressure in millibar by 0.0145 to get your gauge pressure in PSI.
Example:
boost reading with key on/engine OFF = 830mb (roughly 5-6000 feet elevation)
peak absolute boost reading = 2870mb
(absolute boost - atmposheric pressure)* 0.0145=
(2870mb - 830mb) * 0.0145 = 29.58 PSIg
Now lets see what the same absolute pressure would read on a boost gauge at sea level...
boost reading with key on/engine OFF = 1013 mb (average sea level reading)
(2870mb - 1013mb) * 0.0145 = 26.92 PSIg
Or download the Aeroweather app for free. Look up the identifier of your local airport. As a pilot this is invaluable
SCIENCE
I prefer to look at the road and not stare at my boost gauge
Yes, both swaybars ... Enjoy
http://youtu.be/91x6__4tyIQ
Enviado desde mi iPhone utilizando Tapatalk
What sparkplugs is everybody using?
What do you gap them to?
How do you gap them?
Where's the rest of the sparkplug located?
What boost do you spike to?
What boost do you hold?
How do I check for boost leaks?
Why can't I use a bicycle pump?
How much CF do you have?
How do I fix the CF?
Why are GLI's so much better?
Why are my dyno numbers low?
Why do I haul ass at 4500RPM but not 2500RPM?
What do I log for valve float?
What intercooler should I use?
To sum it up, whoever answers these all gets $5 PayPal
PLEZ STICKY
.024"
Feeler gauge
Engine is toasted bud
27 psi
25 psi
Compressor and bubble gum
-3
Catch can, water meth
They aren't
Because
Surge avoidance
Maf and boost
Godspeed
PLEZ STICKY
