So I may be crazy...but I think I may want to try to tackle this over the summer...:iono:
It's a cake walk. EZ as 3.14159265359.
Mostly this. Very time intensive, but not difficult. Just take your time and use plenty of PB Blaster. The only "scary" part is some of the bolts you won't be able to reach with an extractor if you break or strip them.
Yeah that's kind of what I'm thinking. I have the month of June off, and I have a motorcycle to ride around while my car is taken apart. I could see myself taking it real slow and spending 3 days or so on it. It would DEFINITELY be the most involved job I'd ever done, but I think I'm up for it. The bolts do scare me, but pb blaster and the right tools should be my friend.
3 days sounds right. That's how long I took (about 15 hours total) - and it was also the most involved project I'd ever done. Had previously done the downpipe - which is the second most involved (and trivial by comparison).
I mailed my ECU to APR for the reflash before I started.
Day 1 was all prep (removing the downpipe and all the other nonsense), day 2 was removal and bench work, and day 3 was installing the new turbo and reassembly.
Had my ECU back on day 4 and hit the ground.
I'm not sure that would help much. The bolt would expand more than the threads, as they're a part of the block itself.So, for the 6MM hex bolt on turbo heat shield
who is all in favor to use heat torch on it prior to trying to remove bolt? I'll go acquire one...
I'm assuming this has been addressed before...but how do you guys who have done the job feel about this technique of dropping the turbo out the bottom instead?
So here's a $1,500 tip - DO NOT over this gotten the boots on the oil return line. Those little bastard (M6x1.0x16) will snap.
If you do this then PULL THE TURBO before you attempt to extract. I pulled the axle for clearance, but still destroyed it. Wound up drilling it out, and ate right through the bolt's bore hole.
http://www.golfmk6.com/forums/showthread.php?p=2443779
Snug them up, don't crank them down.
Sent from my iPad using Tapatalk
And if you break it, upgrade to big turbo [emoji23]
Believe me I wanted to. Unfortunately I'm buying a house next week (closing Wednesday) - so I'm replacing my APR K04 with the very similar F23T
