sukanas1
Want a murdered out look w/out having to look riced or lame w/ tinted/laminx headlights? Here's a great way to go w/ everything in the housing blacked out! If youre gonna ask about how the high beams.... you dont have to worry about its performance being affected because the projector in the low beam can become your high beam instantly! Check out this video here
btw, its the same projector too just imagine having two of those on!
this setup is all plug and play w/ no error code. you'll need to supply yourself with an H1 HID Kit. You can get one from DDM tuning for around 50 dollars (plus you get lifetime warranty! I've had good service with them). DDM has been the most recommended and error-free kit golfmk6 members have been recommending.
If you go to DDM's website, you'll need:
anyways, here are some pics!
btw, i sourced DEPO lights which let me open the lights via the lens, super clean!
everything is sealed via koito sealant. this is the best/strongest stuff, made by the same company to designed rx and s2k projectors. it seemed like no one was as attracted to m previous one because of the sealing.. hopefully this will change your mind
- Ballast: 35W Ballast
- Bulb Type: H1
- Color: 4500k is closest to OEM, 5000k is more of a 'crystal' white color
- HID Harness: NONE
- HID Eliminator: NONE
- Adapter Cables: NONE
