AliusPrime
BSH 2.0T TSI Engine Mounts
[/IMG]
As we are sure you’ve noticed the factory motor mounts have a ton of give in them, the BSH billet mounts reduce the ability of the engine to flex back by incorporating 78a durometer bushings and the billet bodies to hold them. This bushing set does a great job of limiting movement while still maintaining an acceptable level of comfort needed to be used on a daily driven street car. This will both greatly enhances the fun factor and performance of the car and also removes the all too common problem of blowing out the factory mounts on your higher powered setup.
BSH 2.0T TSI Torque Mount Insert
Under hard acceleration, your entire engine and transmission actually rotate due to the soft rubber used in the factory bushings. While the soft factory bushings do a good job of dampening engine vibration, they can also create a rubbery, vague response from the vehicle..
The BSH torque arm insert works in concert with the OE rubber bushing. With the insert installed, you car's throttle response will feel better and your shifts will feel more crisp and defined as the urethane reinforcement will aid in limiting the amount the engine can rock back under acceleration
BSH 2.0T TSI Pendulum Mount
The kit is a three piece design, a main body, an intermediate body, and a polyurethane sub frame insert. Each component has been designed to accomplish rock solid performance, easy to maintain, and aesthetic enhancement of the respective part of the car. The mount is constructed from billet aluminum right here in our in house machine shop and supplied with OEM high tensile strength hardware. This mount was designed for performance and provides a drastic difference in the stability when accelerating, Shifting, and braking.
BSH TSI Billet Engine Mount:
This kit has a 5 piece design, billet aluminum base, tops, and mounting arms, a 30 ton compression fit stainless steel center shaft, and polyurethane bushings. These reinforced mounts are perfect for the enthusiast who is looking to get the most from their car as they will allow more energy to be transferred to the wheels instead of absorbing the energy into the soft rubber
BSH Billet Transmission Mount:
This kit has a 5 piece design, billet aluminum base, tops, and mounting arms, a 30 ton compression fit stainless steel center shaft, and polyurethane bushings These reinforced mounts are perfect for the enthusiast who is looking to get the most from their car as they will allow more energy to be transferred to the wheels instead of absorbing the energy into the soft rubber.
Benefits:
Includes:
Application Guide:
The following vehicles have been confirmed for fitment. If your application is not listed and you would like to check with us, or if you see an application not listed that you know will work, please post up or email Tech@BSHspeedshop.com and we will get it listed.
In Stock:
These products are considered a normal stock item and will typically ship the same day as ordered. If there is a delay in your order you will be emailed promptly with a lead time and options.
Local Pickup or Fastest Shipping:
North American Motorsports - New York
Ordering:
To place an order for the BSH 2.0T TSI Torque Mount Insert , BSH 2.0T TSI Pendulum Mount , BSH Billet Engine Mount: , or the BSH Billet Transmission Mount: follow the proper link to our secure website. You will receive notifications from processing to completion on the status of your order. We accept all major credit cards, Paypal, money orders and wire transfers.
If you are interested in paying by money or wire transfer, please give us a call or email so we can help you to arrange.
Shipping:
All orders will be shipped FedEX.
International shipping is available through our online store. For multi piece orders please contact us for shipping quotes.
Hours of Operations:
Monday - Friday from 9AM to 5 PM
Saturday and Sunday we stay home but http://www.bshspeedshop.com is never closed!
Contact info:
Phone: 602-606-7973
E-Mail: sales@bshspeedshop.com
We thank you for choosing our products and look forward to working with you from start to finish on your project.
Benefits:
- Significantly reduced engine movement.
- More feedback from the engine
- Greatly reduced wheel hop
- More defined throttle input
- Smoother shifts for both DSG and Manual cars
Includes:
- Billet Aluminum Bodies
- Two piece base with compression fit stainless steel center shaft
- 78a durometer bushings
- Grade 10.9 zinc plated hardware
- Black anodized finish
Application Guide:
- VW MK5 GTI 2.0T TSI Transverse
- VW MK5 GLI 2.0T TSI Transverse
- VW MK5 Jetta 2.0T TSI Transverse
- VW MK6 GTI 2.0T TSI Transverse
- VW MK6 GLI 2.0T TSI Transverse
- VW MK6 Jetta 2.0T TSI Transverse
- VW Eos 2.0T TSI Transverse
- Audi A3 2.0T TSI Transverse
- Skoda Octavia 2.0T TSI Transverse
In Stock:
Ordering:
Shipping:
Contact info:
Phone: 602-606-7973
