Hedgehodge
What little piece, in the bleeder block? If so, no. I just put in the billet kit from ecs because I thought my OEM was leaking around bleeder nipple and letting in air for my clutch issue. Doesn't want to leave 1st gear or sometimes 2nd or 3rd until RPM slows down, very odd none can give me an answer, I think it's the spec clutch kit....
the pedal issue was the plastic piece inside slipped out somehow, I bench bled it and didn't test operation before inserting it. I had to remove it and correct it and bench bled it again, problem solved. Glad I didn't force more PSI to blow master. I removed hoses to see fluid flow to pinpoint it at clutch pedal
