chapusin1
My coolant return line started leaking and it seems like this isn't covered under powertrain warranty, so I bought the part and will be replacing it myself except that I found a little problem, how do I remove this damn bolt in the second picture? Looks to me like I will need to remove the intake tube to access it but as I've never done that, I'm not sure if that's just a rubber piece or if the rubber is actually covering something it and if it is, there will be no room to remove it.
Can someone who has installed a stage 2 carbonio intake chime in? Also, what tool do I need to remove the bolt in the first picture?
Corrosion
End of the intake tube blocking the bolt
Replacement part
Corrosion
Replacement part
