i feel like i have seen someone place a piece of vinyl in the immediate area of the notch, and then filled it in with bondo or fiberglass or something, then they sanded it to be flush.
Since you are in California, you have options, I would suggest a grill or louvers of some type.
These are for the Mk6/MK7
https://www.verus-engineering.com/product-page/hood-louver-kit-golf-r-mk7
Do you think bondo would hold shape over this big of an area?
I was thinking of attaching a plastic notch filler and then applying filler over that.
Just not sure how thats gonna hold up.
Im a bit confused what your getting at here.
Suggesting i put a louver where the notch is?
notch fill with filler might work, but i agree it may not hold up.
i think they misunderstood your original post, thinking you wanted to patch the vents instead of the arc where the emblem sits.
There's no way bondo will hold if you are talking about filling the semi-circle cutout for when the hood would meet the VW emblem on the grill. That area would need a pretty excessive amount of body work, you'd need to support it from underneath, so you'd need to build up fiberglass under the hood, and on top of it, you're looking at a good amount of fiberglass matt, resin, filler, and a TON of sanding, and even then I wouldn't be too confident it'll be up to standard.
So, if I understand what you're trying to fill, then this is not a DIY job, and I suspect most body shops will either tell you to take a hike, or quote you a lot more than it will cost to buy a new hood.
To be a bit more specific, there isn't nearly enough surface area for filler to bond to. You have a very thin (1/4" maybe?) piece to work with, so you'll need to reinforce it top and bottom.
Get a peice of fiberglass cut to shape grind the surrounding area and use tiger hair. Then avoid that spot when you open/close the hood, so it lasts longer
