Recently I have seen a rise in interest in converting a GTI to a golf R.
Why do it? Well, there's a financial consideration, piecing together parts from salvage, eBay, etc can generally yield a cheaper substitute than the 15k upgrade to a golf R. While it's not necessarily the BEST decision, many GTI owners have done so many modifications that they do not want to lose that time and effort, but they want traction for more POWER. This was my case.
On this thread, I am going to try and step through the process, to give those that are curious an idea of what they ACTUALLY NEED in order to accomplish the actual conversion. I will come up with part numbers and equivalents as I get the time. Obviously the ideal scenario is finding a wrecked golf R and swapping on a lift. However, easier said than done.
Here is a quick list of major parts you will need:
1. Rear subframe (houses the rear diff, haldex, rear axles, and suspension
2. Driveshaft or in VW terms, propeller shaft
3. Front differential ( you will need this to connect to the bevel box. You can either do a complete transmission swap, or swap ring gears from the gti differential to the golf R differential)
4. Gas tank and lpfp. this is probably one of the most overlooked items
5. Bevel box, also called the transfer case, sends power to the driveshaft and the passenger axle
6. Rear brakes and rotors.
7. Complete exhaust. Turns out, the GTI downpipe and catback for that matter, wasn't made to fit around a center driveshaft (who knew, right??)
8. VCDS/VAGCOM and cable. You will need to be familiar with the modules and programs as well. You can YouTube it
9. Golf R sway bar
10. Mounting brackets for the center driveshaft support bearing
11. Driveaxles. Only the driver front remains the same
12. All necessary hardware/fasteners. This is literally just a catch-all. Many are different than the GTI because they need to be longer or thicker or just aren't there on a GTI. I know that makes it kind of a crap shoot, but it is necessary
Ok, that's a quick definitive list to get you started. I will be adding pictures and some steps once I get my wrecked conversion back from the repair shop.
9. Golf R sway bar
