So here are the results. I included 2 runs WITH the spring in the DV+. Like I said, I always had weird surging issues after clearing the codes, which you can see in the one run WITH the extra spring.
Granted, this is on a pretty big scale, so the difference between the peak boost you see is actually like .2 psi. Yes, I agree that the DV+ WITH the spring can hold SLIGHTLY better boost.. BUT, the boost curve with the stock valve is by far the smoothest, and although it's under the DV+ WITH the spring at some points, it's only by .2psi.
Like I said above, the car with the stock valve performs the smoothest out of all operational configurations. Also, since switching back to the stock valve my MAF flow reading have now increased back to around where I think they are supposed to be.
Also, I will say despite with the graph says I did feel the DV+ WITHOUT the spring did seem very smooth as well. But since without the spring is still making less boost than the stock valve, I'm not switching it.
I think I'll just be keeping the stock valve in.
EDIT: I just graphed the only other run I took this morning with the stock DV. I was doing pulls in 4th and I only made it to 5800 on the last run so I didn't include it on the graph below. BUT, the peak spike matches the highest peak below (the one with the DV+ WITH the extra spring), and boost stays very similar to to highest points on this graph. I wish I could've gotten a full run in to see what it did after 5800 rpm. Maybe I'll try and get some more data on the way home. I don't want to be too much of an asshole doing pulls from 2-6.5k in 4th on public roads, but I can't do it in third as I usually get a tad bit of wheelspin when full boost comes in.
