Arin@APR
GOLFMK7 Official Sponsor
where on the stock dp would the new O2 sensor need to go?
Right where the hole is on this photo.
On the CBFA turbo they just put it actually on the turbo's manifold.
Can’t you just install the stock downpipe and pass with an appropriate tune?Sooooo
For those who are curious about this...
I have a Mk6 CBFA GTI that I went full out APR on, from the FMIC, Intake, RSC turboback, upgraded valve springs (was getting valve float) K04 turbo... The whole shebang.
In the "good ol days" I could set it to Stock mode, hook up the vagcom and run the readiness routine when the engine and all was warmed up, get 1 not to pass on the cat and be good to pass emissions.
Then one eventful day, my tune at the APR dealer got updated after the whole EPA deal ....
I then came to find out that getting readiness via the Stock mode on the ECU was no longer an option, I was told this was from the EPA crack down.
I eventually came to a point where passing emissions in my County was not feasible for me any longer and the dealerships no longer willing to help in any regard with this, so I heard about this option...
I just got the stock CBFA downpipe modified with an addition O2 bung/sensor up top and the "detuned" K04 program flashed.
For those who are curious, compared to what I had it's sad....., rather sad indeed ...
Responsiveness is gone, both in acceleration and from pulling off from a stop, the car feels like a turbo car again with noticable turbo lag where before it just had constant pull across the board.
Sad days, I guess I'll hold onto the old downpipe in hopes to figure out something to get it back in action in the near future.
This is really what I've done, just that the appropriate tune is the "stock/detuned K04 tune from APR" with the modified stock DP which when I attempted first didn't fit with the APR K04 I had installed all those years back, and required a custom adapter to make work.... (The Stock program in the high torque/flow file stopped allowing the readiness to Pass after the update, my shop said they got told the version I had is no longer available and I'm out of luck for this now)Can’t you just install the stock downpipe and pass with an appropriate tune?
We have never offered anything, at any point in time, that would cause readiness to pass any differently than stock. Never forced. Never altered to pass.I then came to find out that getting readiness via the Stock mode on the ECU was no longer an option, I was told this was from the EPA crack down.
Clarification: We have never, and will never, do anything to make readiness pass.
Thank you, this makes perfect sense and is along the lines of what I suspected.Yea, I had the old K04 file where APR had the o2 sensor monitor turned off(prevent CEL), but since it was turned off the readiness will never be complete. But since the EPA crackdown, every tuner cannot disable any monitors hence the update for all tuners. I did switch to COBB after, since reverting to stock is much easier than having to go to an APR dealer to reflash everytime.
Appreciate you confirming that, I may look into Cobb at some point, assuming you went the custom tune route by uploading recordings for your setup.
Awesome, is your MK6 a CCTA or the dreaded CBFA out of curiosity?Yup, I went with Stratified (https://www.stratifiedauto.com/) for a custom tune, good ppl there. Theres also a stratified owners page https://www.facebook.com/groups/1915271872032293.
Dreaded CBFA lolAwesome, is your MK6 a CCTA or the dreaded CBFA out of curiosity?
Thanks again
As long as all readiness pass it doesn't matter the tune on the Car if you have a CARB sticker. I did not flash back to COBB STG1 from my Stratified tune. I put the Stock DP on drive it there smog it and put the DP back on after. I did this in the beginning of October.
I did it out of curiosity to see if it would fail. It did not.
This is also a reason to go TTE450 if your CBFA because the stock CBFA Down pipe fits. I will see how that goes in a few.
