Here is a little DIY i created for a coilover install.
I'm going to start with the Install. Shipping from Germany was extremely fast. I payed for the Coils on Friday 18th, and had the coils by tuesday the 27th. It came Fed-ex and I received tracking number immediately. Very happy with the speedy shipping.
Packaged Well:
Everything Included in the DTS kit:
Close Up shots of the Quality of the Kit, I was impressed:
INSTALL:
Find a garage with a lift
Make sure you have plenty of fuel...
Remove Wheel
What it should look like:
Remove Lower Strut bolt, and sway bar linkage:
We used an extension to fit into the end of the bolt, worked fine:
Gain access and loosen to the top strut mount bolts by peeling back this piece...
Use a Jack to lift and compress the spring:
Now Take these 3 bolts out all the way:
Use a pry-bar to wedge the collar open that clamps around the base of the strut, these can be the most difficult part (notice the face!):
Now the whole strut/spring assembly should come free:
Remove the strut mount by using a closed end wrench and an allen:
Assemble the new strut, may want to modify the bump stop depending on how low you plan on going. I also installed with the coil spun all the way down so it would be easier.
May help to use a jack to help it into place:
Reconnect the sway bar linkage and lower strut mount bolt:
tighten the top 3 strut mount bolts:
At this point the front should be done, now onto the rears.
Wheel off:
Remove the two upper strut mount bolts:
Using a Close end wrench remove the lower strut bolt, this one is on really tight!
Pop this guy off too:
Now you should be able to take the Strut (and spring) out, Smile like a goon!
Zip off the top mount (dont use an impact to tighten this on your new coils)
Off:
Cut the bump stops, so i wasn't riding on them when I lower it more:
This is how we tightened the strut mount on the DTS coils:
When installing the new spring, we installed so the perch was on top. That way we could adjust the coils without dropping the whole assembly:
Install DTS strut same way you removed the stock one:
Still needs to settle, and wheels. Then more LOW. This is fresh off the lift with about 3/4 of an inch of threads in the rear. The front was set with about 3/4 to an inch of threads left:
REVIEW:
When I first installed the DTS coils, i set them at stock height (all the way up). The performed just like stock, could hardily tell that i had installed the coils at all. I actually thought if anything, they felt a tiny bit "floaty" at this height.
I drove for a day, and then lowered to the current setting. I actually love the ride at this height. It feels better to me. A great comfort level. Stiffer, but still eats up the road imperfections. They feel a lot like the KW coils I had on my old Passat.
I am excited to get some more seat time in the coils, and also to see how low they will go. As it sit now, I will most likely bottom out the remaining threads i have left in the front (about 3/4 of an inch) to get the height I want. At this level there is still a TON of travel up front. So if anything, they could come with a shorter spring so you could go lower up front.
If you want a great every day suspension at a great price, DTS is a great option. I have had KW, ST, H&R, VMaxx, B&G, and Weitec suspensions in the past. Honestly these rank up with KW and the ST's i have had. I loved both of those setups, and really enjoy these.
Just to let everyone know, Glen from the Suspension Source told me I would not be penalized for a negative review. He wanted our complete honesty. So this is what I have given.
Any questions or Comments please, feel free.
Cheers,
Kellen
Disclaimer: Do this at your own risk. I am not responsible for any actions you take. When installing, make sure you tighten bolts according to the recommended torque specifications. Have fun!
Packaged Well:
INSTALL:
Remove Wheel
Wheel off:
Off:
REVIEW:
Cheers,
Kellen
