No acceleration
Gulfcoastbrian
Hello,
I purchased a 2014 Golf R at auction. It is in kinda rough shape under the hood but has a great body and interior. It appears that someone has attempted to start removing the engine for some reason. Has hoses cut and AC crimped. I drove it once for a short distance and it run great. Started noticing it get hot. The radiator hose had a hole. It didn't get real hot though. I stopped immediately. A few weeks later, I went to work on it but battery was dead. Installed new battery and then it would crank right up but wouldn't accelerate at all. It will only go about 2 or 3 miles per hour. Idle speed. Checked spark plugs and the 4th coil pack has no normal residue like the others. Its only firing on 3 cylinders. Can someone p!ease tell me the likely cause. Where should I start with fixing this thing. It only has 60k miles. I know it will make a great car.
Admk2
So they made MK6 R in 2012-13 and mk7 R started in 2015..
So is this a MK6R 2012-13 or new MK7R 2015-19
Scanning for codes would be a start. Fault codes would point to something.
If it's not firing on a cylinder I'd check to see if your injectors are all plugged in and find out if your getting spark in that cylinder from the wire itself.
Joe_Mama
Gulfcoastbrian
Thanks for the reply. It is an MK6R. I’m gonna go check the fault codes tomorrow. All I have is one of the simple cheap scanners but hopefully it will tell me something.
Gulfcoastbrian
I apologize. It is a 2012. I am attaching a picture of the fault codes that it gave. I really appreciate your responses. Can you please give me a better idea of what to do now that I have the fault codes?
