2stroke
Anyone here know anything or having experiences about using the VW Passat B6/B7 Lower Control Arm in Aluminum on VW Golf-5/6 ?
( Ignore the talk about the bushings, my question only concerns the Lower Control Arm itself in Aluminum )
If your Golf-5/6 is experiencing clunking noises, shaking steering wheel, wandering front suspension or just general poor road feel it may be time to replace your front control arm bushings.
A common item to wear out on all VW's, the factory rubber bushings degrade over time, especially when faced with rough road conditions, age or mileage and lowered suspensions,
the front control arm bushings play a critical road in proper road feel and handling of your vehicle.
If it's time for a replacement, don't settle for stock:
Introducing this Upgraded, Lightweight Aluminum Lower Control Arm Kit with pre-installed ECS Polyurethane bushings, for a very simple install!
These control arms upgrade your stock stamped steel or cast steel arms to the lightweight aluminum control arms from the VW Passat's B6/B7 front suspension.
They are an OE-style plus upgrade but offer the following benefits:
A comprehensive upgrade kit made for you, tested and proven in real world conditions.
This kit includes the following:
- Lightweight Aluminum Control Arms:
- Corrosion resistant aluminum.
- 4,1 Kg. combined weight savings over cast steel arms for faster, more responsive suspension operation.
- Enhanced structural rigidity: less deflection over stamped steel arms.
- Polyurethane Bushings:
- Higher load bearing capacity.
- Less deflection for more stable suspension geometry.
- Greater tear strength.
- Greater resistance to environmental wear like water, salt and sand.
- Lightweight Aluminum Control Arms.
- Pre-Installed ECS Polyurethane Control Arm Bushings.
- VW Golf-5/6 Aluminum Control Arm Bushing Housings with Pre-Installed ECS Polyurethane Arm Bushings.
// ECS
