thatspsychotic
Finally reached under the car with my phone, looks like rear main seal leak is confirmed. I assume the actual interface between the engine and trans is further up and still hidden in this photo, but there is a fairly significant amount of oil in that area and it's to the point that I'm seeing oil spots under my car wherever I park now. Also even though there's a bunch of oil on the transmission case itself, I've smelled it and it's definitely engine oil.
To do this job, I assume the following have to be removed:
To save on common labor I'm planning to add in the APR pendulum mount and either Torque Solutions or BFI engine/trans mounts, and if there is common labor, potentially the Tyrolsport deadset and SuperPro LCA bushings. Anything else obvious to include?
- Pendulum mount
- Transmission mount (?)
- Axles (?)
- A bunch of other stuff on top of the gearbox to provide clearance and get at the bolts
