Here is a link to information on Vorshlag camber plates for the Mark V (and a representative confirmed over the phone they also make them for the Mark VI)
just my opinion but the level of NVH from BSH motor mounts are not suitable for DD.
BSH is 78a durometer poly. probably more suitable for track. Smooth ride and drives very well but vibrations are harsh at certain RPM and speed and noise is significantly more noticeable than stock(such as the transmission whirring sound).
Both TT strut mounts and 034 ones are silent and remain silent.
Bruce, I'm gearing up for the Bilstein shocks and struts, I'm ordering new strut bolts and bearings, now just need to price out and compare the 034 strut mounts and the Audi TT strut mounts.
I'd like to follow how this goes for you HYDE. I intend the same dampers and mounts when my car arrives next month. Any info (ordering, install, customization) would prove useful for me (and many others I suspect).
ANY Mk.V camber plate or strut mount will fit the Mk.VI. VW still uses the same top mounts.
Anyway I would not recommend the use of solid mounts on a DD. You'll probably hate the noise.
For what it's worth, I run KW Clubsports with the upper mounts. Solid mounts feel great on the track but are a bit harsh on the street from my experience (at least on Michigan roads). You definitely hear more of a solid "thud" when going over expansion joints or small road imperfections. Not enough to rattle your teeth out, but definitely something to consider. If you track a lot, a must IMO. I run -2.25 camber in the front and can get much more.
I think I want to try that red HPA 75 torque insert.
I looked through Halvie's build and he's running it and so are a bunch of MK6 R's on VWVortex.
About DG springs, they are ok if you live where the roads aren't bad. However, my commute has roads with potholes and seams and the DG springs don't react very well to that type of surface. I would describe the ride as a little softer than stock with a tendency to bottom out or get bouncy when the road is rough. I believe NOLA-RON complained about the same thing.
I mostly likely will be going back to stock springs and a 24mm H&R rear bar to replace my 26/22 H&R setup, both set to hard, during my 20K service.
We are on the same page...
I have the DG springs and I find them rough at times for NJ roads. I'm upsizing to 19" wheels shortly but will also add Bilstein HD shocks/struts to try and smooth things out. I have the H&R 26 front / 22 rear sway bar combo and may up my rear 22 to hard. I also have the HPA red puck and it's great but does cause added vibrations/rattles at low speeds.
You installed the 034 Motorsport or Audi TT strut mounts?
You might want to try Koni FSD's they minimized the crashing I would feel on stock shocks. I had Bilstein touring (black tube) shocks on my Volvo 240 DL with Eibach sport springs and the ride was pan-hard and bouncy.
I'm guessing that the Bilstein HD's will probably ride even harder.
