IHAZTERBO1
Ok, I've looked back and forgive me if this has been discussed before, but...I know a lot of you are in cold weather more then KY is, but its been super cold here lately (5 degrees yesterday morning 22 high). Unit worked yesterday up until I turned the car off and was only out of it for 1.5 hours. Went to start up the car, noticed the clock wasn't on the screen as normal. Pushed the on button and went to hit the Bluetooth and nothing, no beeps no movement. Ok, so tried the fm/am/sat buttons, you can switch between functions but nothing on the screen will change, no beeping as in touching the other stations. I can't get phone calls even though it says telephone, nothing comes through.
So fast forward to this morning. I get in, try again, no clock, press button, no clock, press button longer, clock. Ok, so press button even longer it finally comes on with Welcome to Volkswagen as normal and still nothing. You can turn the volume knob left or right and it is stuck. Could it be to do with cold weather? I know it sounds really stupid to say that but??
Picture below shows, what I mean. It wont go off this level, and of course no sound. I'm so confused as to what it could be and I've googled, searched other forums I'm on and have some that say disconnect battery reconnect, press this button as a hard reset, flashing software as it's out of date.
#1-How would I even know if it's out of date if per say that was the issue? No errors pop up at all.
#2-Any suggestions on what I can do before I take this thing in? I've seen someone say fuse, but I'm not sure that my issue was just like theirs.
#3-If this thing is broken, how hard is it to replace with a non stock touch screen unit?
Any help would be much appreciated!!
