Grabbit
Hey Guys and Gals. So I shot myself in the foot over the holiday weekend.... I thought I'd install my K04 all quick like but I ended up with a broken exh manifold stud in the head that is pretty fubarr'd. I'll likely be pulling the head if I cant get it out and I wanted to make sure I'm ordering the necessary parts to the job right. As a sanity check, can you guys confirm if I got everything? I've already done the chains, tensioner and guides so I'm loosely familiar with timing the engine. I also still have all of the TSI timing tools. Car is a 10 GTI DSG with a CBFA engine. So far I have:
-Head Gasket (1)
-Head Bolts (10)
-Intake Manifold Gasket (1)
-Exh Manifold and DP Gasket (already have)
-Cam Seal (1)
-Valve/Cam cover bolts (22)
-Vacuum pump gasket (1)
-Seal ring for cam bridge (2)
Do I need:
-Cam bridge bolts? I cant remember if these are TTY bolts or not...
-TTY bolts for the vacuum pump or intake manifold? I did a carbon clean about 20k ago and reused these once already...
-What sealant besides the VW stuff does everyone use on the cam/valve cover?
-Head Gasket (1)
-Head Bolts (10)
-Cam Seal (1)
Do I need:
