U102F CEL help!!
Insanetsi
Monday,25,January,2016,15:59:07:54182
VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
www.Ross-Tech.com
* * * * * * * * Address 01: Engine * * * Labels: 06J-907-115-CBF.clb
Control Module Part Number: 1K0 907 115 AT * *HW: 1K0 907 115 AK
* Component and/or Version: 2.0l R4/4V TFSI * * 0040
* * * * * *Software Coding: 040301081C070160
* * * * * * Work Shop Code: WSC 26974 001 1048576
* * * * * * * * * * * VCID: 78F5DAC40B00EDFE49-802C
1 Fault Found:
053295 - Fan Identification Sensor*
* * * * * * * *U102F - 000 - No Communications - Intermittent - MIL ON
* * * * * * *Freeze Frame:
* * * * * * * * * * Fault Status: 10100000
* * * * * * * * * * Fault Priority: 0
* * * * * * * * * * Fault Frequency: 2
* * * * * * * * * * Reset counter: 255
* * * * * * * * * * Mileage: 75210 km
* * * * * * * * * * Time Indication: 0
* * * * * * * * * * Date: 2044.14.03
* * * * * * * * * * Time: 10:17:36
* * * * * * * * * * RPM: 762 /min
* * * * * * * * * * Load: 18.8 %
* * * * * * * * * * Speed: 0.0 km/h
* * * * * * * * * * Temperature: 93.0°C
* * * * * * * * * * Temperature: 41.0°C
* * * * * * * * * * Absolute Pres.: 1000.0 mbar
* * * * * * * * * * Voltage: 13.716 V
Readiness: 0000 0000
Any ideas?
Sent from my XT1254 using Tapatalk
Insanetsi
Full scan if needed
Data version: 20151216
www.Ross-Tech.com
Monday,25,January,2016,16:03:16:54182
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHD7AJ0CW291088 * Mileage: 75270km-46770miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBF) * * * Labels: 06J-907-115-CBF.clb
* *Part No SW: 1K0 907 115 AT * *HW: 1K0 907 115 AK
* *Component: 2.0l R4/4V TFSI * * 0040 *
* *Revision: E3H26--- * *Serial number: * * * * * * **
* *Coding: 040301081C070160
* *Shop #: WSC 26974 001 1048576
* *VCID: 78F5DAC40B00EDFE49-802C
No fault code found.
Readiness: 1110 1101
Address 02: Auto Trans * * * *Labels: 02E-927-770.lbl
* *Part No SW: 02E 300 057 R * *HW: 02E 927 770 AL
* *Component: GSG DSG AG6 * * 512 3115 *
* *Revision: 05551213 * *Serial number: 00001202281286
* *Coding: 0000020
* *Shop #: WSC 01357 011 00200
* *VCID: 2855CA849B20BD7E19-807C
Address 03: ABS Brakes (J104) * * * Labels: 1K0-907-379-60EC1F.clb
* *Part No SW: 1K0 907 379 BJ * *HW: 1K0 907 379 BJ
* *Component: ESP MK60EC1 * H31 0121 *
* *Revision: 00H31001 * *
* *Coding: 114B600C492B00FB880B06EC92210041B70800
* *VCID: 7BFFC5C8FA36C6E624-802E
1 Fault Found:
02214 - Tire Pressure Warning*
* * * * * * 002 - Lower Limit Exceeded - Intermittent
* * * * * * * * * * Fault Status: 00100010
* * * * * * * * * * Fault Priority: 2
* * * * * * * * * * Fault Frequency: 1
* * * * * * * * * * Reset counter: 147
* * * * * * * * * * Mileage: 75110 km
* * * * * * * * * * Date: 2016.01.24
* * * * * * * * * * Time: 12:42:04
* * * * * * * * * * Count: 0
* * * * * * * * * * Count: 32768
* * * * * * * * * * Count: 4608
* * * * * * * * * * Count: 16401
* * * * * * * * * * Count: 51712
Address 08: Auto HVAC (J301) * * * Labels: 3C8-907-336.clb
* *Part No SW: 7N0 907 426 AN * *HW: 7N0 907 426 AN
* *Component: AC Manuell * *H19 0404 *
* *Revision: 00001018 * *
* *Coding: 0000001002
* *ASAM Dataset: EV_ACManueBHBVW36X A01010
* *ROD: EV_ACManueBHBVW36X_VW36.rod
* *VCID: 0005B2249BD0A53E71-8054
Address 09: Cent. Elect. (J519) * * * Labels: 1K0-937-08x-09.clb
* *Part No SW: 1K0 937 086 P * *HW: 1K0 937 086 P
* *Component: BCM PQ35 *M * 110 0651 *
* *Revision: 00110 AC * *
* *Coding: 6F180A3F90272AC4008800C17000056448010386434D8D60648020200040
* *VCID: 3D7B0BD0A4A208D65A-8068
* *Subsystem 1 - Part No: 5K1 955 119 * Labels: 1KX-955-119.CLB
* *Component: Wischer 01031 *26 *0512*
* *Coding: 009795
1 Fault Found:
02394 - Parking Light Left Front (M1)*
* * * * * * 014 - Defective - Intermittent
* * * * * * * * * * Fault Status: 00101110
* * * * * * * * * * Fault Frequency: 24
* * * * * * * * * * Mileage: 74375 km
* * * * * * * * * * Date: 2016.01.15
* * * * * * * * * * Time: 11:02:01
* * * * * * * * * * * * Term 15 On
* * * * * * * * * * Voltage: 14.25 V
* * * * * * * * * * * * ON
* * * * * * * * * * * * Term 50 On
* * * * * * * * * * * * OFF
Address 15: Airbags (J234) * * * Labels: 5K0-959-655.clb
* *Part No SW: 5K0 959 655 H * *HW: 5K0 959 655 H
* *Component: AirbagVW10G * 013 0724 *
* *Serial number: 003GVRA1S03X *
* *Coding: 00003131
* *ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
* *ROD: EV_AirbaVW10SMEVW360_SE36.rod
* *VCID: 3F8771D8A6AE1AC648-806A
* *Seat occupied recognition:*
* *Subsystem 1 - Part No SW: 5K0 959 339 B * *HW: 5K0 959 339 B
* *Component: BF-Gewichtss. *006 0001*
* *Serial number: ---0000R--00003JBW00
* *Crash sensor for side airbag; driver side:*
* *Subsystem 2 - Part No SW: 5K0 959 354 * * HW: 5K0 959 354*
* *Component: S.Sens.Fahr.V *H01 ----*
* *Serial number: 3572MSME5073026CZZZS
* *Crash sensor for side airbag; front passenger side:*
* *Subsystem 3 - Part No SW: 5K0 959 354 * * HW: 5K0 959 354*
* *Component: S.Sens.Beif.V *H01 ----*
* *Serial number: 3582MSME6F2F346BZZZD
* *Crash sensor for side airbag; rear; driver side:*
* *Component: S.Sens.Fahr.H *--- ----*
* *Serial number: 3512QSME6C010E2DZZZ$
* *Crash sensor for side airbag; rear; passenger side:*
* *Component: S.Sens.Beif.H *--- ----*
* *Serial number: 3522QSME56126D11ZZZR
* *Crash sensor for front airbag; driver side:*
* *Component: F.Sens.Fahr *--- ----*
* *Serial number: 35527SME22046C2BZZZF
* *Crash sensor for front airbag; front passenger side:*
* *Component: F.Sens.Beif *--- ----*
* *Serial number: 35627SME7706692BZZZP
Address 16: Steering wheel (J527) * * * Labels: 5K0-953-569.clb
* *Part No SW: 5K0 953 507 AH * *HW: 5K0 953 549 B
* *Component: Lenks.Modul * 008 0080 *
* *Revision: -------- * *Serial number: *90422LC500056
* *Coding: 189A140000
* *ASAM Dataset: EV_SMLSNGKUDS A05001
* *ROD: EV_SMLSNGKUDS_SE36.rod
* *VCID: 76E9D4FCC9149B8E5B-8022
* *Multi Function Steering Wheel Control Module:*
* *Subsystem 1 - Part No SW: 5K0 959 542 * * HW: 5K0 959 542 * Labels: 3C8-959-537.CLB
* *Component: E221__MFL-TAS *H08 0010*
* *Serial number: 0016341 * * * * * **
* *Coding: 830000
Address 17: Instruments (J285) * * * Labels: 5K0-920-xxx-17.clb
* *Part No SW: 5K6 920 972 C * *HW: 5K6 920 972 C
* *Component: KOMBI * * * * H03 0607 *
* *Serial number: 00000000000000
* *Coding: 270F01
* *ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
* *ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
* *VCID: 366914FC8994DB8E9B-8062
Address 19: CAN Gateway (J533) * * * Labels: 7N0-907-530-V2.clb
* *Part No SW: 7N0 907 530 M * *HW: 1K0 907 951*
* *Component: J533 *Gateway H42 1623 *
* *Revision: * H42 * * * Serial number: 040312F2001302
* *Coding: 350002
* *VCID: 3A7100CCB58C3FEE7F-806E
Address 1C: Position Sensing * * * *Labels: 1Kx-919-xxx-1C.lbl
* *Part No SW: 5N0 919 879 * * HW: 5N0 919 879*
* *Component: Kompass * * * * 001 0001 *
* *Revision: 00001000 * *Serial number: 1225223RH76106
* *Coding: 0000002
* *VCID: 7EF9CCDC2924D3CE03-802A
Address 25: Immobilizer (J334) * * * Labels: 5K0-920-xxx-25.clb
* *Part No SW: 5K0 953 234 * * HW: 5K0 953 234*
* *Component: IMMO * * * * *H03 0607 *
* *Coding: 000000
* *ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
* *ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
* *VCID: 6AD1F08C8DAC4F6ECF-803E
Address 2E: Media Player 3 (J650) * * * Labels: 5N0-035-342.lbl
* *Part No SW: 5N0 035 342 E * *HW: 5N0 035 342 E
* *Component: SG EXT.PLAYER H13 0240 *
* *Revision: A1001003 * *Serial number: 7662076113 * *
* *Coding: 010000
* *VCID: 2953CF80402A847606-807C
Address 42: Door Elect, Driver * * * *Labels: 1K0-959-701-MIN3.lbl
* *Part No SW: 5K0 959 701 B * *HW: 5K0 959 701 B
* *Component: Tuer-SG * * * * 009 2119 *
* *Coding: 0001204
* *VCID: 316327E0A8FAFCB6CE-8064
Address 44: Steering Assist * * * *Labels: 1Kx-909-14x-44.clb
* *Part No: 1K0 909 144 P
* *Component: EPS_ZFLS Kl. 74 * * 3305 *
* *Revision: 00H22000 * *
* *VCID: 377719F8469E228680-8062
Address 52: Door Elect, Pass. * * * *Labels: 1K0-959-702-MIN3.lbl
* *Part No SW: 5K0 959 702 H * *HW: 5K0 959 702 H
* *Component: Tuer-SG * * * * 009 2105 *
* *Coding: 0001204
* *VCID: 38751AC44B802DFE89-806C
Address 56: Radio (J503) * * * Labels: 5M0-035-1xx-56.clb
* *Part No SW: 1K0 035 180 AE * *HW: 1K0 035 180 AE
* *Component: Radio Prem-8 *H02 0016 *
* *Revision: -----16S * *Serial number: VWZ4Z7M1108183
* *Coding: 01000400040005
* *VCID: 63CF9DA862861E260C-8036
1 Fault Found:
02635 - Tuner Not Enabled/Activated*
* * * * * * 000 - *-*
* * * * * * * * * * Fault Status: 01100000
* * * * * * * * * * Fault Priority: 7
* * * * * * * * * * Reset counter: 88
* * * * * * * * * * Time: 10:18:39
Address 62: Door, Rear Left * * * *Labels: 1K0-959-703-GEN3.lbl
* *Part No SW: 5K0 959 703 D * *HW: 5K0 959 703 D
* *Component: Tuer-SG * * * * 007 2101 *
* *Coding: 0001168
* *Shop #: WSC 01357 011 1012552
* *VCID: 356B13F05C92D09692-8060
Address 72: Door, Rear Right * * * *Labels: 1K0-959-704-GEN3.lbl
* *Part No SW: 5K0 959 704 D * *HW: 5K0 959 704 D
* *Coding: 0001168
* *VCID: 366914FC4194DB8E9B-8062
Address 77: Telephone (J412) * * * Labels: 7P6-035-730.clb
* *Part No SW: 5K0 035 730 E * *HW: 5K0 035 730 E
* *Component: TELEFON * * * H09 2902 *
* *Revision: 1B001001 * *Serial number: 00007661969835
* *Coding: 0A10040000010100
* *ASAM Dataset: EV_UHVNA A01719
* *ROD: EV_UHVNA.rod
* *VCID: 2757C9B85E3EB20610-8072
End-------------------------(Elapsed Time: 02:34)--------------------------
Francoleon91
Lol this fucking code.... I got this code when I bought the car 2 years ago and to this day I still get it. Comes and goes and comes and goes, pretty sure is the same code as U1030. I took it to the dealership last year and the dude said it was a faulty sensor on the radiator and I would have to replace the whole thing but I was tuned so they couldn't do anything about it warrty wise. i just live it with now, sometimes it comes on 3-6 times a week sometimes I doesn't come back in months. If anyone has any other info please tell, other wise the car is fine, it doesn't effect drive ability.
Dr Dad
My codes!! I get both the U102F and U1030 and have no idea what they mean...
It's never affected drivability and I got my radiator replaced about a year ago (didn't get the code before then), so I've just lived with it. Glad to see others experience this code :thumbsup:
goose1
Yup that's the sensor on the front of the radiator, tamper proof and you can usually only buy it with a new radiator direct from vw
Sent from my XT1575 using Tapatalk
goose1
Keep an eye out for 8P4965873A, that's the sensor part number
goose1
Dr Dad
Thanks Goose!
rs999
Reviving this old thread but I have had these codes for about two years now. And I can't get rid of them or the CEL.
4 Faults Found:
053296 - Local Databus
U1030 - 000 - Electrical Malfunction - Intermittent
009576 - Sensor for Ozone Reducing Radiator Identification
P2568 - 000 - Implausible Signal - MIL ON
008577 - Performance Malfunction in Cooling System
P2181 - 000 - - Intermittent
I brought the car to the local VW dealer, they said they would try replacing the whole radiator to fix the issue. I passed on this option for a second opinion.
At my local independent, he said the issue was a sensor and that maybe APR could turn off the codes with a custom Stage 3 flash.
I don't have any issues with driveability or performance. I daily drive, track, time trial, and sometimes autocross this car. And I have never had an issue with overheating or the car going into limp mode.
Should I have the independent replace the radiator or should I try the sensor, 8P4965873A, that goose mentioned? I believe both options would be a dis-assembly of the front end.
Thanks.
zrickety
The Fixer
P2181 is usually a thermostat. I would try a new Ozone sensor and a waterpump.
Francoleon91
4 Faults Found:
Thanks.
were would you buy the sensor from? would you get it from the dealer? because i cant find it anywere.
