VAG-COM (VCDS) helper
danielj1
I did DRL's off and windows up with remote. Thanks for this great info!
MK05-HJ09
Well, so far I've only done the windows up with the remote mod, considering turning off the DRLs to prolong the life of my bi-xenon components, maybe switching to the fogs instead?
RiVoT1
dhillon
Steering assist change
Got a Blue Graphite 3dr Gof 2.5 Sportline (Canadian Car) :happyanim: and am looking to do a couple of vagcom changes. This thread has been awesome. Just wondering if there is there a way to reduce the steering power assist through a vagcom setting? If feels a bit to light for my taste. I recall seeing a way to change on a MK5 Golf but can't seem to see if there is a way on the MK6.
ackjaf
i've been looking for this too. i don't think it's possible though from what i've read around the net.
Dana @ Ross-Tech
What do you mean by cornering lights using fogs?
On vehicles with factory fog lights, the 09 - Central Electronics (BCM) module can be coded to enable this feature. When you turn the wheel -or- turn on the turn signal (depending on the coding selections) the fog light turns on that side of the car.
This deactivates at higher speeds, perhaps over 15 ~20 Mph, but don't hold me to that value. Also see the "--- Lighting ---" section in my Mk6 thread for the coding.
This is not the same as the Xenon AFS "steering" lights, or the Corner Lights feature. The Adaptive Frontlight System is controlled by the Xenon module ( Address 55 ).
mk62011
I just run Vag on my car and found some error can someone help me to figure it out?
The problem with my parking light is because i replaced it with another bulb so it's through codes so it's fine but i don't know what wrong with the cornering lamp and the electrical malfunction ??
Thanks!!
Here are the code :
1 Fault Found:
530190 - Local Databus: Electrical Malfunction
U1030 00 [008] - Defective
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 115
Mileage: 1600 km
Date: 2001.14.29
Time: 23:23:36
4 Faults Found:
02235 - Stationary Cornering Lamp (Left) (M51)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:04:18
Freeze Frame:
Term 15 On
Voltage: 12.90 V
ON
ON
Term 50 Off
OFF
OFF
02236 - Stationary Right Cornering Lamp (Right) (M52)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:04:19
Freeze Frame:
Term 15 On
Voltage: 12.95 V
ON
ON
Term 50 Off
OFF
OFF
02395 - Parking Light Right Front (M3)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:05:00
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
Term 50 Off
OFF
OFF
02394 - Parking Light Left Front (M1)
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 2790 km
Time Indication: 0
Date: 2002.14.12
Time: 19:05:01
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
Term 50 Off
OFF
OFF
LittleJohny
^ Looks like your headlight fluid may be a bit low
Dana @ Ross-Tech
Thanks!!
Stationary Right Cornering Lamps aren't installed in the Golf, so it looks like the 09 coding is messed up. You may have a bulb check issue beyond any "cold lamp diagnosis" coding tweaks if they aren't resistor style bulbs.
Please edit that to include the complete module ID, or better yet, post the complete Auto-Scan. If you have the original coding please include it.
