Dumb question on your custom splashguards, do you have them on the rear and if so, pics? They look much more subtle than the factory ones. I like them!
i dont have them on the rear since i had to mod them to fit the front and i couldnt figure mounting points for the rear to work....
Alittle explanation how i made them work:
since on the front i use the 2 screws that hold the wheel liner on as attachment points, and modded & added a third screw toward the inside of the wheel well (Where the wheel well recesses) to support the mudguard from flexing. which took some time to figure out (ended up having to make a small cut to fit a clip, something like this but not really (See A) and a screw with a washer and nut. Alittle over engineered but it works great.
A
The only way to make rear mud guards to work is to have them clip on the paint which was what i was trying to avoid with these, so i just didnt even try to mod them to fit.
But thanks for the compliment man! and yea i dont like the OEM ones, bc i dont like how they clip on paint, and how they look. if you want a DIY ill try my best to PM you one thats more in depth. should of made one when i installed them.
All in all took an hour for both sides, first side was 45 min, 2nd side was 15 min.
