no idea. I just looked on google for a pic. Search on google, ebay or you could easily have one made locally at a sticker place.
Thanks, I've found a few at 2.5" diameter that might be an option...
The airbox has rubber grommets included. These go in the two holes in the bottom of the box then press down onto the factory airbox studs. You have to go slowly and correctly aligned or you'll push the grommets out of the airbox and end up with a loose fit.
I think the sound is good (I've disconnected my soundaktor) and I'd say its equal to or better than the Carbonio in that aspect. Performance wise, I have the stock flash but I'd say the slight improvement over stock is comparable / equal to the Carbonio I prev had.
Yes, it should have had donut-looking grommets for those holes, 2 of them.
You may want to pull the intake box and check under/behind the filter. One or both of mine were inside it and kind of stuck/lodged under the filter inside the intake box. If not hit up AutoAnything or Volant.
Maybe I should contact autoanything... I wonder if Volant could supply me with two of them? They're pretty close to me.
I'd just contact Volant directly
