Modshack1
This Brake Mod seems to be the most sensible and practical. I try to follow these threads closely. I do have a couple of questions.
1. Are spacers needed for the OEM 18" rims? Honestly I hate running spacers though I realize I am sure it would be minimal, it still places more of a load on the bearings. I am sure 5mm wouldn't hurt too bad, but still. I just want to confirm that you do or do not need spacers.Depends totally on your wheel design. Mine cleared by1.5mm with no spacers (RS3 reps)
2. The REFIRB kits on RockAuto seem to be a pretty good deal, you would need to swap the bleeders and such, but has there been any issues from REFIRB calipers from RockAuto? Rock Auto is pretty stand-up from my experience
3. The changing of the Banjo bolt, and Brake Lines. I need a little more clarification on that. You just buy new Banjo Bolts and any Brake Lines for a GTI will work? Not sure...I used new stainless lines with the proper fittings. I think R32 lines are correct, or just order from Apikol as mentioned earlier
4. The solid Metal pieces that go inside the pistons. Are those necessary if your using the shims? You would think if you used shims with some high temp Copper paste on the backside you shouldn't have any issues? or those solid pieces are actually necessary? These are the same as shims with anti-vibration properties. I would HIGHLY SUGGEST you use them unless you like the fingernails on a blackboard screech. These were the only things that worked for me.
5. OEM Brake Pad Sensor. Does the Porsche pads use a sensor in the brake pads like the VW ones do? And if they do, do they plug right in to the VW connector? or does all that get disconnected? If so, does a dash light come on thinking your pads are wore? Porsche pads actually have 4 sensors. Don't use them, not plug compatible. Cut your old sensor off your old pad, splice the two wires together (solder and shrink wrap) and plug back into the car. You'll have no light. I'm assuming you maintain your car so have no need for these silly wear sensors
Really doesn't seem too bad of a job, just want to get as much info as possible.
Thanks Everyone.
Jeff
Good luck!
