XGC75
Speaking of, I just bought some RAAAAAAIHMMZZ.
This is actually a pretty good savings for me:
- For one, I need to buy a set of hub rings after I broke one trying to pry it off the hub as I changed to the winters this fall.
- Second, I need two center caps for the nurburgrings.
- Most importantly, I need summer tires. I think I posted the status of the PSS's after the track day at Autobahn earlier. They're not even good enough to trust on a drive down to Tire Rack to get new tires fitted.
- Lastly, I'm sick of steelies for winters.
I wanted to work out a way to get into some 18's for the daily set and at the same time relegate the Nurburgrings to my winter 17"set. What I found was a set of TSW Interlagos, 18x8 ET45 5x112, silver with machine-cut face. They're about 18lbs a corner, only a few ounces more than the Nurbs at 17x8. They're wrapped in Falken tires, which isn't my preference, but according to reviews they're quiet and comfortable if a little light on the mileage capability. All in all this setup provides an easy solution for the center cap, hub ring and tire problems all while dropping the steelies for about $100 more than it would have cost to buy new summer tires, hubrings, center caps now and cheap OEM 17's with tires for the winter. That said, my car budget is back in the red for the summer. I'll be able to swing the strut mounts and bearings for the DG spring install but that's about it.
