bart2278
Anybody using pure meth injection instead of mix?
I have seen guys using 70/30 and 80/20 in here. I don't think I have seen pure meth being used though.
well i'm joining the club now guys
I've been collecting a few parts so far:
BSH throttle pipe
SNOW upgraded solenoid (for just past the tank I believe)
BSH Pump bracket
SNOW pump, 300psi
MAF-U controller
Still need:
Tank, low level sensor, low level alert
Line
Nozzles (anyone have recommended starting points for a dual nozzle on a K04 setup?
Throttle spacer plate
2 more solenoids, one prior to each nozzle
I am in the midst of planning a cell phone gauge pod. I will have a cell phone mounted somewhere at all times communicating through one of the car diag apps via a bluetooth obd2 pigtail. I think as far as tuning goes i need to watch AFR and dial it in, then get my 100 octane tune and re-dial it in?
I appreciate it.
From some further reading, i am thinking it may be worthwhile to keep one solenoid between the pump and tank as well, to ensure the pump never has a dry moment.
So to confirm the order of operations:
Tank
Solenoid
Pump
Solenoid
T fitting
Checkvalve close to nozzles
Nozzles
ah yes, didn't think about a particle filter. That's important, as particles can definately clog a little nozzle.
Just doing all I can to make sure i can SAFELY run a race fuel tune with meth.
Thanks!
and further down the rabbit hole i go... i'm only aware of a few failsafe systems, AEM and maybe Aquamist? These are gauges &sensors that automatically cut things like boost/timing etc if it senses a problem right?
so i'd be looking into these?
https://www.snowperformance.net/Snow-Performance-Safe-Injection-Unit-p/30020.htm
https://www.snowperformance.net/Safe-Injection-Boost-Solenoid-p/30100.htm
good chance they would 'play well' considering everything else I have so far is SP. I'll keep looking into all of this, because yea once I'm done collecting all the parts I'd not be far off from the price of an HFS-4 kit which is like 900 bucks...
And yes, I have WAY over the cost of an HFS kit sunk into my system. If I could sell it all and do it over I wouldn't hesitate. The HFS-4 is just a complete, fail proof system that works and injects on so many different levels then "boost" and "variable pump voltage".
