WhiteJames
Fun Nazi
VW Racing.co.uk (VWR) Spring Specs:
VWRacing.co.uk sport spring spec as quoted directly from VWRacing.co.uk. Specs for springs are similar:
Cheers.
WJ
The front spec is:
- Lowering range 20-25mm
- Spring rate 31N/mm
- Wire diameter is 13.25 mm
- Coils 6
- I will have to find out what % uprated they are
- It is a linear rate, however the spring is a barrel type spring so they end forms come slightly in.
- These will fit direct on to the standard dampers and don’t require anything else.
The rear spec is:
- Lowering range 20mm
- Spring rate 33N/mm
- Wire diameter 12.5mm
- Coils 8.5
Cheers.
WJ
