Old 03-07-2018, 03:04 AM   #71
Yadadameans
Yadadameans's Avatar
Drives: CSG GTI
I just did some data logging last night on Stratified base map tune last night. Just sent my logs over to them. Feel free to look at my numbers and see if anything looks wrong
https://datazap.me/u/hkindahouse/log...og=1&data=6-30
Yadadameans is offline   Reply With Quote
Old 03-07-2018, 07:48 AM   #72
redubbed
Originally Posted by KFahey View Post
Is it sealed around the seem where the ring meets the turbo flange around the outside? I don't see weld there
Sent from my SM-G935V using Tapatalk
I didnít bother with the ring. Itís welded directly to the compressor housing.
redubbed is offline   Reply With Quote
Old 03-16-2018, 09:24 PM   #73
zef
Just wanted to bump this thread as I bought an HPA KO4 and I keep hearing people saying the actuator on the HPA unit is 'weak' - can someone who has experienced this elaborate further? I was planning on purchasing a forge unit based on this research but I wanted a little more feedback before I do so.
Old 03-18-2018, 02:26 PM   #74
redubbed
Basically a "weak" wastegate actuator would cause low or inconsistent boost.
Old 03-18-2018, 06:05 PM   #75
zef
That part I got, I was just curious what they were running at the time (e30, meth, aggressive tuning, etc) that they would've had to replace the wastegate actuator to get what they were looking for.
Wasn't sure if it was weak because people were asking too much of it, or if it was more widespread of an issue
Old 03-18-2018, 06:16 PM   #76
redubbed
Itís likely the same reason the diverter valves theyíre using are ďrepsĒ to hit a price point with the turbo to be competitive. Casting & machining those housings probably isnít cheap, so they use aftermarket components for the rest, including the actuator.
Obviously a more aggressive tune/mods will ask more of the potentially crappy actuator, thus the varied results.
I think itís worth the extra upgrades to make a good bolt-on turbo ďkitĒ great.
With the Forge actuator & OEM electrical things, it should perform solidly. Plus, with the SoCal Porting port & ceramic coat, itíll spool close to stock.
Old 03-18-2018, 11:48 PM   #77
zef
My thoughts exactly! That's the plan for my Ko4 as well. Will be sent over to SoCal as soon as my turbo gets here Tuesday.
Thanks for the input!
Old 03-19-2018, 04:08 PM   #78
GroovyVW
Who in SoCal are you using to port and polish?
Sent from my iPhone using Tapatalk Pro
GroovyVW is offline   Reply With Quote
Old 03-19-2018, 10:04 PM   #79
zef
It's the actual name of the company. SoCal Porting
https://socalporting.com/
Old 03-21-2018, 04:27 PM   #80
redubbed
Canít recommend these folks enough, excellent pricing & customer service.
Old 03-21-2018, 04:55 PM   #81
Yadadameans
Drives: CSG GTI
+1 for Socal Porting as well
Old 03-22-2018, 01:43 AM   #82
GroovyVW
Thank you for the info
Old 04-25-2018, 04:35 PM   #83
franco516
franco516's Avatar
Drives: gti
what TOP do you guys recommend for this turbo? paired to a ARM fmic. Are TOPS even necessary?
IG - @francotirador91
Old 04-25-2018, 06:38 PM   #84
Jerseynoob
Drives: 2010 Jetta Wolfsburg
Waste of money.
Not necessary.
Have 80k on my HPA, never needed one.
Jerseynoob is offline   Reply With Quote
