Ok so I woke up a bit late and didn't have time to take any pics, but I have about explained it as best I can. Has anyone else run into this issue?
Were you able to fix this issue? If so, how did you do it?
Sent from my SPH-L900 using Tapatalk 2
Old thread, but my car (2011 cbfa gti) is in the shop right now getting SPM IC and APR K04 installed. Mine has the sensor and the guys ran into problems when spacing the radiator. Luckily they have stock radiators lying around so they are going to replace the radiator and see if APR can fix the cel in the tune. Best fix to have everything fit properly if you ask me.
i have a 2012 CBFA and just installed a Neuspeed FMIC along with TOP and air charge pipes last weekend. I've been getting low coolant warning and also the P2568 code and Sensor for Ozone Reducing Radiator Identification.
I didn't remove the stock IC, so I don't think it's exactly the same problem, but i"m wondering if the Neuspeed is causing issues with the sensor on the radiator.
My coolant has been going low a lot lately, so I'm actually thinking it may be something else... Did anyone have coolant issues at the same time as this error?
