Ever since I installed my carbonio I've been having very frequent and very annoying MAF issues. What happens is when I'm going WOT above 4500 in second or third and up shift quickly boost/fuel completely cuts out in the next gear (ex when im shifting from second to third quickly in higher rpms as soon as I get into third and put my foot down power is completely gone and boost gauge reads 0 until I remove my foot from the throttle and re apply it)
I figured that the oil from the filter had gotten on the maf so I cleaned it with some contact cleaner and the problem was fixed for about a month. I then changed my filter to an AFE Pro Dry S and cleaned the maf again which fixed the problem for another month until it came back AGAIN:mad0259:. When I run the car mafless the problem is fixed but my fuel economy is horrible. I am not sure if I should buy another maf from the dealer because it may break again and i'd be out a couple hundred bucks. I am going k04 soon and would like this problem resolved before then so anything helps. Thanks
