there's a guy selling his stage 3 kit on fb for $2500 i believe. i'd pull the trigger on that. you can make good usable power and have a lot of room to grow. i'm not a big fan of the f23t either. while the numbers are impressive, moving the power up top instead of increasing the spike down low will make more, safer, usable power and is plenty of fun.
plus you don't have to spend all the money up front. get a tune and a boost controller and you can bump it up yourself as you go (i.e. adding fueling, building motor, etc.)
Short will do it. And 115 is way low, spec is 160 min my mkv and mk6 both were 180 all across 1psi here or there
got some bits back from shave/polish/powder...
all hot parts back from ceramic coating today as well. no pics of those yet tho. wrapping them in ptp lava wrap!
Don you should really get a photo of your car / engine bay up here so people can see the gold/black batman theme....
? Min spec is 7 bar or 101psi. This is also cold without the engine running prior to so no oil to help seal rings?
