40,000mi service (DSG) is $800!!!??? HELP!!!
stevenchkim
Before I spend $850 for a tranny fluid change, I will......
A) Light my car on fire
B) Trade my car in and take a $2,500 hit
Do B, then A. But then it won't be your car you're setting on fire, and likely a felony. Maybe rethink this when you're sober, have a Penrose sausage, and shop around for a indie mech who can handle the job.
Gti For Me
1 liter of fluid is 18.00 X 5
1 filter 10.00
2 hours labor at 105.00 X 2
Thats at my dealer i seen a board on the wall with prices and i think total job is like 350.00.
You spark plugs dont need to be change till 60K sevice
Service at 60,000 miles
t AdBlue Fluid: Check and add if necessary (3.0L TDI engine only)
t Airbag System: Perform visual inspection (Every 1 year regardless of mileage)
t Air filter element and snow filter: Replace and clean housing (if applicable) (Every 6 years regardless of mileage)
t Battery: Check (and second battery if applicable)
t Brakes: Inspect brake system and shock absorber for leaks and damage, check thickness of brake pads, brake disc condition and check brake fluid level
t Convertible roof: Check latch: (if applicable) (Every 2 years regardless of mileage)
t Dust and pollen filter: Replace (if applicable) (Every 2 years regardless of mileage)
t Engine: Change oil and replace oil filter
t Fuel filter: Replace (2.0L TDI and 3.0L TDI only)
t Haldex Clutch: Change oil (if applicable)
t Hybrid components: Perform a visual inspection of high voltage components and the lines in the engine compartment and the rear of the vehicle for damage
t Rear window: Check cleaning nozzle functionality (if applicable)
t Service interval display: Reset (if applicable)
t Service sticker: Enter the date of the next service on the service sticker and apply to the driver's side door pillar
t Spark plugs: Replace (2.0T, 3.0L Hybrid and 3.6L only)
t Timing Belt: Check (2.0L MPI only)
t Tires: Check tread depth, condition, tire age, wear pattern and pressure of all tires (including spare)
t Tires: Rotate front to rear
t Tire mobility kit: Check and observe expiration date on the tire filler bottle (Every 2 years regardless of mileage)
t Tire pressure sensors: Replace (Every 6 years regardless of mileage)
t Windshield washers, headlight cleaning system, and wiper blades: Check for damag
Gti For Me
Golf/GTI
Caution
All quantities are approximate. Always refer to the Repair Manual and/or the Maintenance Procedures for correct filling instructions.
Refer to Technical Bulletin 2012855 for engine oils meeting the required VW oil specifications.
Part numbers are for reference only. Always check with your parts department for the latest information.
Component/System Capacity Part Number/Specification
2.0 L TDI Engine
Oil and Filter Change 4.3 L (4.5 qt.) VW 507 00
Coolant 8.0 L (8.5 qt.) G 012 A8G
2.0T Engine
Oil and Filter Change 4.6 L (4.9 qt.) VW 502 00
2.5 L Engine
Oil and Filter Change 5.5 L (5.8 qt.) VW 502 00
Coolant 9.0 L (9.5 qt.) G 012 A8GF
5 Speed Manual Transmission 0A4
Initial Fill 1.9 L (2.0 qt.) G 052 512 A2
Refill 1.7 L (1.8 qt.)
6 Speed Manual Transmission 02Q
Initial Fill 2.3 L (2.4 qt.) G 052 171 A2
6 Speed Automatic Transmission 09G
Initial Fill 7.0 L (7.4 qt.) G 055 025 A2
6 Speed Direct Shift Gearbox 02E
Initial Fill 6.9 - 7.2 L
(7.3 - 7.6 qt.) G 052 182 A2
Refill 5.2 L (5.5 qt.)
Brake System
- 1.2 L (1.3 qt.) B 000 750
A/C System
Refrigerant 525 ± 25 g
(18.5 ± 0.9 oz.) See ETKA
PAG Oil, Sanden 110 ± 15 cc
(3.7 ± 0.5 fl. oz.) G 052 154 A2
PAG Oil, Denso 6SEU14C 90 ± 10 cc
(3.2 ± 0.3 fl. oz.) G 052 300 A2
PAG Oil, Denso 7SEU17C 140 ± 10 cc
(4.7 ± 0.3 fl. oz.)
PAG Oil, Delphi 110 ± 10 cc
(3.7 ± 0.3 fl. oz.) G 052 154 A2
PAG Oil, Delphi, GTI 110 ± 10 cc
(3.7 ± 0.3 fl. oz.) G 052 300 A2
Window/Headlamp Washer System
With out headlamp washer 3.6 L (3.8 qt.) G 052 164
With headlamp washer 5.0 L (5.2 qt.)
Edition-091710
Gti For Me
Service at 40,000 miles
t Body: Visual inspection for corrosion
t Convertible roof, CSC roof, and retractable hard top: Check for function and damage, clean and lubricate seals (if applicable)
t Coolant level and frost protection: Check
t CV joints: Check for leaks and damage
t Door checks and mounting pins: Lubricate
t Engine and engine compartment components: Check (from above) for leaks and damage
t Engine and engine compartment components: Check (from below) for leaks and damage, check transmission, final drive, and drive shaft boots
t Exhaust system: Check for leaks, damage and secure fittings
t Headlights, daytime running lights, curve lighting, and automatic headlights: Check adjustment
t Interior lighting and glove box lights, cigarette lighter / power outlets, horn, and all warning lamps: Check
t Lighting: Front and rear lights, luggage compartment lighting, turn signals, hazard warning lights: Check
t Power steering: Check oil level
t Ribbed V-belt: Check condition
t Spark plugs: Replace (2.0L MPI only)
t Spark plugs: Replace (2.5L only)
t Sunroof and panoramic sunroof: Check, clean, and lubricate (if applicable)
t Sunroof: Open sunroof and check front water drains and clean if necessary (if applicable)
t Test drive: Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning, and handling
t Tie rod ends: Check for excessive play, check boots
t Tire mobility kit: Replace tire filler bottle (Every 4 years regardless of mileage)
t Transmission: DSG (non automatic): Change fluid and filter
t Underbody sealant: Inspect for damage
t Windshield washers, headlight cleaning system, and wiper blades: Check for damage and function, Check fluid level and add if necessary
Spark plugs are replaced for 2.5 l and 2.0 none turbo cars
corrado917
Not long ago I did my service and was quoted at my "Stealership" with the same $800 bucks.I separated the service with two other bigger VW dealers and just for the Dsg service ended up paying away less than $400.Search around your area,not all dealers do special and charge your not for the difficulty of labor but for the amount of workers they hire..
roastpuff
Local VW-specialist shops do DSG flsuh for around $300 in my area. A dealer will also do it for that price, or even slightly cheaper ($275).
Shop around, see what you can find.
09vdubgti
Banned
im doing my 40k maintenance by parts since it is lots of $$ to do it at once. Did the oil change at the dealer did the rest myself...Saving up $$ to do the dsg oil flush. Im glad spark plugs dont have to be done till 60k, dealer themselves told me I dont have to change the fuel filter either right now it could wait along with the air filter.
Optical TDI1
So what if I asked them to do JUST the DSG fluid change
Why not ask the dealer since they, not us, will be the ones to set the price. It's only every 40k miles, so big deal if it's $400-$500 for just the DSG service....about 1 penny per mile and do the rest yourself which is the smart thing to do. Save $4 per week in a cookie jar and you won't have these issues!
maxtdi
ok, lets break this down.
Last i checked at 40k you should get (about average prices at dealer)
New Cabin Air filter ($80)
Oil/Filter ($100)
DSG dervice ($400)
Spark Plugs ($120)
$700 or so.. at "standard" prices...
You're not just getting the DSG service, you're getting the 40k mile service. This is nothing out of the ordinary.
SRT2GTI
Banned
That's straight raping right there. I thought the Exo X MR SST transmission service was expensive at $250.00...VW Charging $800.00 is beyond outrageous.
CrzyP
Considering how much a new DSG transmission costs, I think the routine maintenance is a small price to pay for some insurance.
