Service at 40,000 miles
t AdBlue Fluid: Check and add if necessary (3.0L TDI engine only)
t Airbag System: Perform visual inspection (Every 1 year regardless of mileage)
t Battery: Check (and second battery if applicable)
t Body: Visual inspection for corrosion
t Brakes: Inspect brake system and shock absorber for leaks and damage, check thickness of brake pads, brake disc condition and check brake fluid level
t Convertible roof, CSC roof, and retractable hard top: Check for function and damage, clean and lubricate seals (if applicable)
t Coolant level and frost protection: Check
t Convertible roof: Check latch: (if applicable) (Every 2 years regardless of mileage)
t CV joints: Check for leaks and damage
t Door checks and mounting pins: Lubricate
t Dust and pollen filter: Replace (if applicable) (Every 2 years regardless of mileage)
t Engine: Change oil and replace oil filter
t Engine and engine compartment components: Check (from above) for leaks and damage
t Engine and engine compartment components: Check (from below) for leaks and damage, check transmission, final drive, and drive shaft boots
t Exhaust system: Check for leaks, damage and secure fittings
t Fuel filter: Replace (2.0L TDI and 3.0L TDI only)
t Headlights, daytime running lights, curve lighting, and automatic headlights: Check adjustment
t Hybrid components: Perform a visual inspection of high voltage components and the lines in the engine compartment and the rear of the vehicle for damage
t Interior lighting and glove box lights, cigarette lighter / power outlets, horn, and all warning lamps: Check
t Lighting: Front and rear lights, luggage compartment lighting, turn signals, hazard warning lights: Check
t Power steering: Check oil level
t Rear window: Check cleaning nozzle functionality (if applicable)
t Ribbed V-belt: Check condition
t Service interval display: Reset (if applicable)
t Service sticker: Enter the date of the next service on the service sticker and apply to the driver's side door pillar
t Spark plugs: Replace (2.0L MPI only)
t Spark plugs: Replace (2.5L only)
t Sunroof and panoramic sunroof: Check, clean, and lubricate (if applicable)
t Sunroof: Open sunroof and check front water drains and clean if necessary (if applicable)
t Test drive: Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning, and handling
t Tie rod ends: Check for excessive play, check boots
t Tires: Check tread depth, condition, tire age, wear pattern and pressure of all tires (including spare)
t Tires: Rotate front to rear
t Tire mobility kit: Check and observe expiration date on the tire filler bottle (Every 2 years regardless of mileage)
t Tire mobility kit: Replace tire filler bottle (Every 4 years regardless of mileage)
t Transmission: DSG (non automatic): Change fluid and filter
t Underbody sealant: Inspect for damage
t Windshield washers, headlight cleaning system, and wiper blades: Check for damage and function, Check fluid level and add if necessary
Spark plugs are replaced for 2.5 l and 2.0 none turbo cars
