Looks amazing. Clever solution with panty dropper results as per
Lovely subtle & clean wagon!
I've read some of the threads on the OEM xenon installs.. so you had to install a highline CECM + snake the bi-xenon trigger wires from the harnesses through firewall? How painstaking of a process was it?
That's sorta it, but not quite.
You'll need the following:
Then, you'll need to:
- OEM LED Bi-Xenon housings
- Ballasts (2)
- All associated bulbs
- Highline CECM (in my case, from an 14' Autobahn GTI)
- 14 pin VW harness connectors
- VW repair and trigger wires
- VAGCOM cable and VCDS
- Cloth OEM style wiring tape
Huge time-saver here if you want Xenon factory lights but don't care about the LEDs.
- Repin your 12 pin harness to a 14pin harness for your headlings. Halogen harnesses arent the same. Alternatively, Kufatec makes adapters, but you'll have an extra two plugs and wiring in the bay. I opted for the OEM wiring route.
- Run two trigger/power wires for the LED modules. This is the most time consuming part. It involves unwrapping the factory harnesses, place the new wiring and rewrapping with the cloth electrical tape.
- Fish the two new trigger wires through the firewire and into the floorboard.
- Remove your existing CECM and install the highline module.
- Pin the two fished wires into the CECM.
- Install the housings, bulbs and ballasts.
- Program the lights.
* I did the above on my last build GTI, you can find more info on that earlier in this build thread. A midline CECM will work with non-led Xenon lights.
- Purchase Golf R headlights
- Purchased Kufatec wiring harness adapters
- Jump the 10 and 12 pins on the harness
- Plug the the new modified harnesses in.
- Install lights
- Check 'has Xenon lights' in VCDS.
- You're done.
Pardon me, I just briefly looked for it (roughly page 4 right?) but didn't really see anything more. Do you have more info on this? I know about the Kufatec adapters that I believe were plug & play, but what do you mean by "jumping the 10 & 12 pins"?
I cared about LEDs when I was 21 and gave too much shit about form over function, but 8 years later with every car having LEDs, I could not care less about them and would gladly get the Golf R non-LED ones. Besides, I've ran my fogs as DRLs the last 9 years.
Anyways, my biggest issue was installing a highline CECM + the trigger wires through the firewall and I frankly didn't have the time, patience, or room. All MK6 GTis came with at least a mid-line CECM right?
I love how sculptured-out the lower outer flanks are. If I copy/honour your front end......Got the R-Line front-end conversion ordered!
The Mk6 Golf had an R-Line in Europe, but not the NA market. This included:
I've already done the headlight retrofit, Golf R side skirts and OEM Votex rear valance, diffuser and spolier extension, so this order contains all of the other parts and pieces. I've never seen a Wagen R-Line conversion, so hoping this will be unique while staying true to t
- A unique front bumper specific to this trim level (kinda like a 35th GTI version bumper for a Golf)
- Gloss lower center grille
- Gloss black fog light surround trim
- Highline upper grille
- Golf R side skirts
- R-Line fender badging
- Bi-Xenon LED headlights
I've already done the headlight retrofit, Golf R side skirts and OEM Votex rear valance, diffuser and spolier extension, so this order contains all of the other parts and pieces. I've never seen a Wagen R-Line conversion, so hoping this will be unique while staying true to the OEM+ build theme.
To finish off the front end, I have this SRS lower lip coming as well. Due to COVID-19 and overseas shipping, my estimated arrival date isn't until August 1-3.
And now we wait...
