how do you wire the LED? Do you just get a tap and tap it into the ignition wire of the switch? I used to hear something before when I turn on the accusump, now I don't hear anything anymore so I think that one of the wire might be bad.
I'm using the INA's supplied sandwich plate, which is just a Mocal sandwich plate. The one I have has a built in thermostat unlike OP, which doesn't. I have this one but with different fittings.
http://www.racerpartswholesale.com/product/14809/Mocal_Sandwich_Plate
I however don't know the thread of the adapter bolt
The sandwich plate takes literally 5 mins to put on so I would advise to do it last and focus on measuring the hoses and fittings. It's a veryyyyyyy tight fit, I have to unbolt the coolant line? or something for it to fit. You would also need a 1-inch socket.
We can't just use this with the threaded portion from an oil filter?
https://www.fourseasontuning.com/mo...mostatic-sandwhich-plate-kit.html?mfg_id=1104
the only issue is the adapter in the middle. I couldn't find that thread at any hardware store.
Just got my stuff from Four Season Tuning. Extension fits the part from the oil filter, and all screws together as expected (tested on my extra cooler assembly).
How hard is it to take off that cooler assembly? What all does it entail?
This is off one of my spare motors. But to do that in the car, alternator and a/c compressor need to come off. And this connects to the waterpump, but I don't see why you couldn't get this off while leaving the pump on. Obviously you'll be rained on with coolant, and oil, but that's a different story.
What about just removing the oil cooler? Or does the whole assembly have to come off?
So the threaded portion in the center of the sandwich plate came off an old oil filter and screwed straight into the Mocal plate? If so that's awesome, makes life looking forward much more simple, hahaJust got my stuff from Four Season Tuning. Extension fits the part from the oil filter, and all screws together as expected (tested on my extra cooler assembly).
