PR_dub
GREAT.. yesterday was a looong day. I began early in the morning to install some audio equipment I gathered for some while now and had not yet come around to actually put it to work. So long story short, the actual install went along well.
Wrapping things up around 10pm, we finally hooked up the battery to move the car so we could finish cleanup and head home when... the car stalls out.
When the car stated for the first time, I noticed the lights dimmed when turning the wheel, but said to myself "might be that the battery drained a little", and also a couple lights came up on the dashboard: Yellow steering wheel light, ESP Error, and TMPS. Going along with it, I moved the car and parked outside(stepped out of the car and left it running thinking it was a little drained) so that the shop owners' truck could be locked up for the night. barely 30 seconds after stepping out of the car, it suddenly stalls, and a I rush to it to see what happened. I quickly tried to start it again and it started but died quickly. after that, turned over but didn't run. I ended going home in the shop truck and left the car at the shop.
I read up on many installs here on the forum to be sure how to remove every single panel touched (including glove box and center console). Everything seems to be good with fuses and there is power to the car entire car...
Today, I went back to charge it up a little and try to start it again. after a quick charge the car started! only for 1 minute... and again, it turns over but doesn't run.
Anyone know what the heck happend here??
mods in sig
mods in sig
