Fergusdaddy
I successfully changed the footwell lights to red LEDs as well. What I can't figure out is how to reverse the passenger side light so the wires are facing the outside of the car to make the light spread better. It seems as if the wires aren't long enough to reach to the other side. Any help?
That's weird, when I removed the metal box there was about 3 inches of play in the plug and wires hanging through the hole. You may find your wires are snagged on something behind the plastic fascia, as there are a few tabs sticking out under there. Or maybe your wires have a cable tie around them that is closer to the plug than mine. Only way to check is to get your head under there with a torch, and that involves lying upside down in the seat with your head in the footwell! Hope your carpet is clean!
