I know I'm necrobumping, but I just replaced my brake pads, lines, and rotors and had a heckuva time trying to get the rear caliper carrier bolts off so wanted to post a couple cautions and tips for people.
1. The caliper carrier bolts are stretch-bolts and not supposed to be re-used, so make sure you buy some if you're replacing your rotors (I've heard arguments that the dealer never changes them, however the bentley repair manual recommends replacing them and VW says to too... plus they're only like $4).
2. The top caliper carrier bolt is near impossible to remove with the car on jackstands because you have very little room to move the ratchet or get a breaker bar underneath the car to get leverage, and the control arm is kinda in the way. If you have the car on a lift it might be easier, but if you're using jackstands you might have to remove the bolt holding the lower control arm so it'll swing down and give you more room. I had to remove the lower control arm bolt on the passenger side because when I tried doing it without removing it there wasn't enough room for me to get leverage on the top caliper carrier bolt. So, my triple square bit getting deformed and i had to get a new one. Once I tried the second time with the lower control arm bolt removed it was a lot easier and I got the caliper carrier bolt out.
Also for the top caliper carrier bolt, unless you have a shorter triple square bit or a thinner ratchet, the rear sway bar will probably be in the way and you'll need to remove the hub/pinch bolt above the rotor to fit a ratchet on the top caliper carrier bolt.
For anyone planning on doing this job themselves, hope this saves you some frustration..
