Noob_2.0T
Got it working. Redid the jumper wire and seems to have a better connection and now working.
Went back to 15 for byte 18. 22 disables drls.
So byte 18 set to 15 works for cars with led rear lights with rear fog.
Only problem now, the side markers are on with the drls. Is this the same for everyone? Anyway to get them off? (besides color coded replacements and removing the bulbs).
EDIT: don't got it. Damn drl left and right bulb out errors and the xenons are flickering on startup. Maybe need another byte 18 code.
Wish someone could help :-(
EDIT 2: changed byte 18 to 04 this morning and seems to work better. No bulb out error so far. LEDs and sidemarkers are actually now brighter and rear LEDs and rear fog works fine.
Would like the sidemarkers off in drl mode though.
Maybe this helps someone else
So from what I read if I read it right you have the LEDs as DRL's? I also have euro switch with OEM LEDs with rear fog and I would like to be able to not turn my switch to the park position to be able to have the LEDs on. My current set up when I turn it to parking I get LEDs in front, side markers, and tails light up. Ill hook up to VAGCOM tomorrow and get a read on what I have right now. I just want to be able to have the LEDs on for DRL's so I don't have to keep turning my switch on. Help would greatly be appreciated
