It's takes 5 mins with VAGCOM - literally check 2 or 3 boxes.
Thanks for the answer, could you please tell me which of the coding I use because am so confused. My car is a Golf 6 1.4 Tsi 2009 model.
Revolver66 said:For the GTI:
for front fog as drl along with LED----
BYTE 18 - is 20
BYTE 14 - is 0B (check bit 1, bit 3)
BYTE 15 - is C4 (check bit 6, bit 7)
BYTE 24 - is E4 (check bit 7)
BYTE 27 - is 24 (check bit 2)
this is the following
LED DRL and FOG light DRL at the same time
to have JUST LED DRL:
same as above with this one exception:
BYTE 14 - is 09 (check bit 3
Is it normal to get the drl bulb out indicator? I have led option
Any way around this?
Awesome thanksFollow instructions in my post right above yours and then
Only issue now is the orange side markers are always on. Any way around this?
For the people who had issues with the lights but still have a functioning HID kit, have you tried to install it in your halogens? Aside from that being the incorrect thing to do, does Ed's HID kit fit or work in them?
