GolNat
ALK kit is installed and front LCA bushings have been replaced with Super Pro poly ones. Car still needs an alignment but I decided to get a sub frame bushing kit before I get another alignment. Reached out to ECS about purchasing their sub frame spacer kit but without the bolts since I already have them. They told me they come packaged that way
. Super helpful, so I bought a CTS kit from Urotuning instead. Ordered Tuesday and arrived at my door Friday!! Urotuning Rocks ?. Sunday I will start on the sub frame kit and try to get an alignment scheduled for next week. Once aligned I'll give my impressions of the ALK.
The bushings came out easily once I stopped trying to make everything straight and pretty. Just get er close enough and push it out.
Make sure you use a lot of lube. You get a tube with the ALK and a tube with the other LCA bushings so that's a tube per arm. I used about 75% of each tube on each arm.
Original GTI LCA weight with bushings.
Passat LCA weight with bushings.
Installed on the car.
Also got a shift knob after #knobchat in the ChiChat thread. Bought it off a forum member. I understand why people love their Slammer shift knobs. Super high quality and heavy AF. I need to get used to it. It has brought to light some of the short comings in the OEM shift assembly and I don't think that is helping. I can see a Diesel Geek in my future as well.
K04 fund is slowing growing. Stage 2 is loads of fun which means K04 has got be TONS of fun.
