thanks dude... but I.. I... am mechanically declined... pics of said area?
file itself is free. update /"labor" do it varies by tuner.
Open hood, look down, you'll see this,
See that silicone hose middle left and the pipe attached to it going down?
This is that pipe off the car and the sensor location,
You can see the sensor in the first photo if you draw a line straight down from that green connector. VERY easy to do. It's two torx screws. Pulls right out and new one goes right back in. Wham, bam, one and done.
How are you guys getting the car into the shop after you replace the MAP sensor? Will the car even start or run properly from the parking lot to the shop floor? The reason I ask is I was quoted an hour labor to replace the MAP sensor. So while the update is free, I was going to have to pay an hour for the MAP sensor and an additional half hour labor for the flash.
Car will run. You just shouldn't romp on it because it will be getting bad values. An hour to install the sensor? That's hilarious. It will take them honestly 10 minutes to replace.
I mean... given the photo above, how long would it take you to unscrew those two torx, disconnect the old sensor, reconnect new sensor, and tighten the two torx back? They just want to make monies.
